Are you looking for Full-Height Heated Holding Cabinet with Fixed Wire Slides - Solid Dutch Doors - Grey? We found best price for you. Go to link below to buy the Full-Height Heated Holding Cabinet with Fixed Wire Slides - Solid Dutch Doors - Grey for the lowest price.
Full-Height Heated Holding Cabinet with Fixed Wire Slides - Solid Dutch Doors - Grey Review
To sum it up, I would recommend people to buy Metro Full-Height Heated Holding Cabinet with Fixed Wire Slides - Solid Dutch Doors - Grey at Compact Appliance. For 2025.00 it's just excelent!
Full-Height Heated Holding Cabinet with Fixed Wire Slides - Solid Dutch Doors - Grey Description
Add a versatile, heated container to your commercial catering or cooking enterprise with the Metro Full-Height Heated Holding Cabinet (C539-HDS-4-GY) . The cabinet's holding module allows it to work overtime, holding hot foods at impeccable temperatures between 80 and 200 degrees Fahrenheit. The holding module does it all: analog temperature controls allow you to set temperature on the fly, while a passive humidity generation system ensures that delectable foods don't get dried out. A digital temperature display provides a quick readout of interior temperatures to make sure dishes come out perfectly. This 3-series cabinet isn't just made up of sturdy aluminum that will easily stand up to heavy use and wear. It also features innovative insulation armor, a durable, polymer exterior shell that is dent, impact, and stain resistant. Additionally, the shell is cool-to-the-touch: molded-in hand holds offer a great way to move the cabinet around, all the while retaining heat and saving energy. On the inside, a smooth polymer drip trough with catch pan helps contain interior messes, and the control module is removable for easy clean up. Neoprene-wheeled casters feature ball-bearing axels and swivels, are nickel-plated, and have two brakes. A door-mounted gasket ensures a tight, heat-retaining seal, and the door's handle is a magnetic pull-latch with lever action. Fixed Wire Slides:Nickel-chrome electroplated wire slides spaced 3 apart Capacity:Can hold up to 17 18x26 pans or 32 12x20x2.5 GN 1/1 pans Solid Dutch Doors:Two insulated aluminum doors offer quick access and heat retention Holding Module:Electric control module controls temperatures with analog dial and offers passive humidity generation for holding hot foods
Related posts
- Full-Height Heated Holding Cabinet with Fixed Wire Slides - Solid Dutch Doors- Red
- Full-Height Heated Proofing and Holding Cabinet with Universal Slides
- Vulcan 13 Pan Commercial Heated Holding Cabinet
- Dawn Kitchen RTC342231-05 Solid Wood And Plywood In Light Coffee Finish Wood Stands Cabinet With Two Doors
- Springfield Fixed Height Pedestal, 15" Rise
- First Team Fixed Height In-Ground Basketball System - Brute Extreme
- First Team Fixed Height Basketball System - Legend Supreme Dual
- First Team RuffNeck Select Fixed Height Inground Basketball System - 60 Inch
- Wire Stripper-Cutter - Solid and Stranded Wire
- DMi Keswick 72.25 in. Hutch-Wire mesh doors
- 10500 Series Storage Cabinet w/Doors, 36w x 20d x 29-1/2h, Mahogany
- Hospitality Wall Cabinet, Two Doors, 36w x 14d x 30h, Natural Maple
- 11500 Series Valido Storage Cabinet w/Doors, 36w x 20d x 29-1/2h, Mahogany
- Mayline Napoli High Wall Cabinet with Doors Sierra Cherry
- Solid Oak Table w Split Angled Top & Drawer (60 in. L x 36 in. W x 37 in. H w/ 18 in. Fixed Top)
- Solid Oak Table w Split Angled Top & Drawer (48 in. L x 36 in. W x 37 in. H w/ 12 in. Fixed Top)
