Are you looking for Roland Sands Design Tech Fuel Gauge Cap With LED Fuel Light Contrast Cut? We found best price for you. Go to link below to buy the Roland Sands Design Tech Fuel Gauge Cap With LED Fuel Light Contrast Cut for the lowest price.
Roland Sands Design Tech Fuel Gauge Cap With LED Fuel Light Contrast Cut Review
I recommend buying Roland Sands Design Roland Sands Design Tech Fuel Gauge Cap With LED Fuel Light Contrast Cut .It has some nice quality and it's definitely worth 139.95
Roland Sands Design Tech Fuel Gauge Cap With LED Fuel Light Contrast Cut Description
Snap-in cap to replace the left side OEM fuel gauge. Designed to match RSD gas caps. CNC-machined from billet aluminum. Left-side cap features a built-in low-fuel LED warning light; push-in installation and wiring harness included. User-programmable to light the LED at any pre-set fuel level. Fits all bikes with left-side analog gas gauge. Available in chrome, Contrast Cut or Black Ops finish. Contrast Cut finish starts with a polished gas cap that has been black anodized, then recut to open up the design. Black Ops is perhaps the toughest yet, featuring a gloss black on top of a contrasting textured black finish. Interchangeable RSD logo badge (black and brass) (except Vintage style) . Made in the U.S.A.
Related posts
- Roland Sands Design Fork Clamp Mounts For Tracker Turn Signals 41mm Contrast Cut
- Roland Sands Design Tracker Fuel Gauge Cap Without LED Fuel Light Contrast Cut
- Roland Sands Design Turbine Air Cleaner Contrast Cut
- Roland Sands Design Moto Shift Linkage Rod Contrast Cut
- Roland Sands Design 5 3/4 Tracker Headlight Contrast Cut
- Roland Sands Design Vintage Shift Linkage Rod Contrast Cut
- Roland Sands Design Tracker Grips Machine Ops
- Roland Sands Design Lazy Boy Handlebar Black
- Roland Sands Design Convoy Handlebar Chrome
- Roland Sands Design Nostalgia Cam Cover Black Ops
- Roland Sands Design Nostalgia 4-Bolt Handlebar Risers 1 1/4 Handlebars Contrast Cut
- Roland Sands Design Chrono Upper Fork Covers Contrast Cut
- Roland Sands Design Moto Crossbar Handlebar Contrast Cut
- Roland Sands Design Cafe Gauge And Headlight Relocator Black Ops
- Roland Sands Design Nostalgia 2-Bolt Handlebar Risers 1 Handlebars Contrast Cut
- Roland Sands Design 5 3/4 Chrono Headlight Chrome
