Are you looking for Vizio M55-C2 55-inch LED Smart 4K Ultra HDTV - 3840 x 2160 - (Open Box)? We found best price for you. Go to link below to buy the Vizio M55-C2 55-inch LED Smart 4K Ultra HDTV - 3840 x 2160 - (Open Box) for the lowest price.
Vizio M55-C2 55-inch LED Smart 4K Ultra HDTV - 3840 x 2160 - (Open Box) Review
This led tvs arrived shortly and ive had em since January and ive had no problems since would recomend to anyone that needs led tvs!
Vizio M55-C2 55-inch LED Smart 4K Ultra HDTV - 3840 x 2160 - (Open Box) Description
Vizio M55-C2 55-inch LED Smart 4K Ultra HDTV - 3840 x 2160 - 20,000,000:1 - 360 Clear Action Rate - Wi-Fi - HDMI. (Open Box) This is an Open Box item in original manufacturer condition, includes accessories, and carries the manufacturer warranty. If the manufacturer is unable to assist with the warranty, Tech For Less will warrant the item with the same coverage as the manufacturer. Manuals and software might not be included, but can usually be downloaded from the manufacturer. These items can be in the original manufacturer box or repackaged for protection during shipping. Model Number: M55-C2 Product Name: Vizio M55-C2 55-inch LED Smart 4K Ultra HDTV Product Type: LED Smart 4K Ultra HDTV Screen Size: 55-inch Backlight Technology: Full Array LED Aspect Ratio: 16:9 Smart TV: Yes PC Streaming: Yes Internet Access: Yes Media Player: Yes Standard Refresh Rate: 60 Hz Enhanced Refresh Rate: 240 Hz Maximum Resolution: 1920 x 1080 Scan Format: 1080p Speakers: Yes Ethernet: Yes Ethernet Technology: Ethernet Wireless LAN: Yes HDMI: Yes USB: Yes Composite Video: Yes Component Video: Yes Network (RJ-45) : Yes Energy Consumption per Year: 244.2 kWh
Related posts
- VIZIO D32-D1
- Samsung UN60H6203 60-inch LED Smart TV - 1920 x 1080 - 240 Clear (Refurbished)
- Sony FWD75X850C 75" 4K/UHD Pro Bravia Display - 75" LCD - 3840 x 2160 - Direct LED - 2160p - HDMI - USB - Wireless LAN - Ethernet
- Samsung UN65JS9500 - Open Box 65-inch Curved 4K SUHD Smart LED TV
- Samsung 48 Ultra-Hd 4K Smart Tv With 6' Hdmi Cable
- LG 55UF7600 - 55-inch 2160p 120Hz 4K Ultra HD Smart LED TV w/ WebOS Hook-Up Bundle
- 4.3mm, Sterling Silver, Open Link Chain, 24 inch
- 8mm Stainless Steel Open Curb Chain - 24 Inch
- Blanco 520286 19 Inch Undermount Single Bowl Fireclay Bar Sink with 7 Inch Bowl Depth, Rear Drain Placement, Easy to Clean Surface and Ultra Durable
- Samsung UN60JU6500 60" 4K Ultra HD 2160p 60Hz LED Smart HDTV (4K x 2K) - Qualifies for Premium Delivery
- Sharp Aquos Q Series LC-60EQ10U 60-inch Smart LED TV - 1080p (Refurbished)
- 3.2mm Stainless Steel Open Cable Chain - 20 Inch
- 5mm, Silver Elongated, Open Link Chain, 24 inch
- Stainless Steel Hammered Open Heart Necklace - 18 Inch
- 14K Yellow Gold, 6mm Open Link Bracelet - 8 Inch
- Ultra-Thin Omni-Directional Indoor HDTV Antenna, Amplified, 60-Mile Range
